Hot water cylinder circulator
View the thread, titled "Hot water cylinder circulator" which is posted in UK Plumbers Forums on UK Plumbers Forums.
After some advice, i have recently had solar panels fitted and have an Eddi which uses the energy we generate to heat the cylinder using the immersion heater.
Just wondering if there are any devices that can circulate the hot water in the cylinder so the immersion heater heats all the water not just the water at the top of the tank.
Proper solution would be to get a new cylinder with a 2nd immersion heater element, but looking for some temporary solutions (if there are any).
FYI cylinder is a vented (low pressure) and just has immersion heat at the top and normal coil connected to the gas boiler.
Reply to the thread, titled "Hot water cylinder circulator" which is posted in UK Plumbers Forums on Plumbers Forums.
chris020,
fowlerboi,
