View the thread, titled "Hot water cylinder connection" which is posted in Bathroom Advice on UK Plumbers Forums.
K
Kathleen
I've moved my cylinder and because the elbow which was fixed to the top of the tank was now pointing the wrong way and I could not get out the remains of the old pipe, I had to remove it and hope I haven't damaged the tank. Now I need to get another connection to replace it and I don't know what sort of connection I need and if I need to use a washer.
Nor do i without a bit more info. But some thing like a 1" male to 22 mm bent copper to iron is a description that will get you a fitting. It is usual to wrap PTFE tape around the 1" thread before screwing into the cylinder connection. Good Luck
Thank you for your reply, the fitting I removed had a lip above the thread that screwed in to the cylinder connection, that's why I wondered if I needed a washer, because it looked like it was meant to have a washer on the lip. I don't want it to leak! Kathleen
It has a parallel thread and the shoulder you describe could be fitted with a washer but is usual to wrap a large amount of PTFE around the thread and tighten to the direction you require. Try not to turn back. Good Luck
Reply to the thread, titled "Hot water cylinder connection" which is posted in Bathroom Advice on Plumbers Forums.
