T
thedivvy3
I have a customer in Cornwall who has had someone install her hot water cylinder (Heatrae Sadia Indirect 210i Megaflo Eco Unvented cylinder I think, going there today and will check) in her stone built shed which has no insulation worth mentioning and nothing additional put around the cylinder.
As a side note she runs off a bore hole with all the associated pump, filter, etc in the same shed and last year the uninsulated pH cylinder froze and split (original plumbers said it wouldn't be a problem!)
I am surprised that the cylinder is installed as it is, surely this is not good?
Any comments/advice about changes required would be appreciated.
Cheers
Cheers
