T
Tuafan
Hi there,
we have a low pressure hot water system - header tank in ceiling, and a 180litre main cylinder. It is a very old cylinder, and is now leaking slightly from the bottom.
In my attempts to temporarily fix the leak, we turned off the tap from the header tank to the main cylinder, and emptied the cylinder. We have now turned the tap on the header tank back on - but the cylinder is only filling with a few litres - maybe only about 30 at most? Subsequently it is near impossible to have a shower, etc because there is very limited hot water pressure. I turned the mains power to the cylinder off, as I am worried it may burn out with not enough water in it.
Did we do the refilling wrong? Do we need to do this over again, have the house taps all on when we turn the header tank tap on, or do we need to have them off? Is there something else we need to do that we haven't done? 😕
Thanks heaps - any basic advice (novice DIY person here!) would be great thanks. We really need to get this fixed ASAP as the children and my Wife arn't to happy about no showers!
Thanks again,
Trevor
Thanks again,
Trevor
