Hi all ,
Got a job that has a reoccurring blockage on the hot side to sink tap only, system is cylinder with cwst in loft space. Initially owner thought they had a faulty tap and changed it no water came out but sucked through with wet vac.
Ran it for 5 mins after and all worked fine, later today had a call same cust kitchen tap has stopped again, went out just a drip from hot tap again.Speedfit under sink so pulled apart fitting and nothing but a drip so its defo not the tap. They have a hot tap in basement which works fine , hot tap in cloakroom toilet works fine which is on same floor as this tap ,and main bathroom toilets hot taps work fine.
what do you guys think ?
