Hot water goes to header tank when powerflushing forward flow,help!
View the thread, titled "Hot water goes to header tank when powerflushing forward flow,help!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi
I have a gravity-fed system I have flushed it out a couple of times and it has had x400 in the system for the last 4 weeks.
There was one radiator with stubborn flow left which doesn't heat up enough, it has 8mm pipes which I think is the problem, rather than the rad as I have had the rad off and it has good flow with a hose pipe.
I put a Fernox Powerflush pump on with forward flow today but I am just getting hot water in the heater tank and it goes to the header tank overflow. Reverse flow is ok.
What should I do to remedy and flush out the system?
I could put a valve on the expansion overflow to somehow limit the flow but a still allow expansion overbiously thats not strictly legit blocking an expansion......
I wante to increase the concentration of x400 to a higher convcentration and have the one stubborn rad being circulated to try and remove the pipe sludge.
Reply to the thread, titled "Hot water goes to header tank when powerflushing forward flow,help!" which is posted in UK Plumbers Forums on Plumbers Forums.
diy_massacre,
diy_massacre,
