View the thread, titled "Hot water in shower but not taps" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
J
jaimelee
I was wondering if someone could help me with some advice.....
I recently moved into a flat which only has electricity, no gas. The water is set to heat overnight on a timer (economy 7). I have hot water in my shower everyday but no hot water coming through any of the taps. If I 'boost' the water heating during the day I can get hot water through the taps but this is heated at a premium cost. Surely the water heated overnight should flow to both the shower and the taps? It would be great to get your thoughts....
Was just about to reply but refreshed screen first - must admit I hadn't thought of an electric shower. My suggestion (same as WaterTight's) is the immersion heater for the Economy 7 (lower heater) has stopped functioning and quickest (and probably cheapest) fix is to drain the cylinder then replace it.
Thanks for the replies.
I'll check tonight to see if the immersion gets hot. If i need to replace it do you have any idea how much it should cost?
If you're calling out an independent plumber and the job goes easily around £70 all in. If he can't turn off the water supply to the tank easily or encounters hassle when draining it then it's around £20-£30 an hour on top of this. Also he might suggest you change the top one as well as they often fail within months of each other.
9 times out of 10 you should see change from £100.
Where I live (in a rural cave with more sheep than people in these parts) it's £40-50 callout/first hour, then around £20£25 an hour and £150-£180 a day. This is for most construction trades (electricians, plumbers, builders, decorators, tilers, etc). Granted some people charge more and some much less (one or two only ask £100 for a day's work!) but in the rural areas (Devon, Cornwall, Norfolk, Wales, ***bria, etc) these prices seem fairly standard.
Perhaps that explains why most of us drive around in clapped out cars and ancient vans. My van's 3 years old and is far newer than other vans owned by people I work with and is also newer than just about all my competitors' chariots.
Reply to the thread, titled "Hot water in shower but not taps" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
