View the thread, titled "Hot Water intermittently Cutting In & Out" which is posted in Bathroom Advice on UK Plumbers Forums.
A
ajf01923
My Alpha Ocean 280p combi boiler intermittently cuts in and out when delivering hot water only. Alpha themselves suggested replacing the DHW temperature sensor - which has been done - yets the issue is still there.
Any help would be great.
I should have added the diverter valve was replaced 6 weeks ago. I've managed to nail the issue down to when the (hot) taps are fully open. When open half way the problem does not occur. Any ideas what this could be?
i would think that your maximum gas pressure on the dhw is too high
check with MI and set accordingly sometimes a restricted secondary heat exchanger will cause this
Reply to the thread, titled "Hot Water intermittently Cutting In & Out" which is posted in Bathroom Advice on Electricians Forums.
