HOT WATER KEEPS CUTTING OUT? - Remeha Combi-Boiler E7 error
View the thread, titled "HOT WATER KEEPS CUTTING OUT? - Remeha Combi-Boiler E7 error" which is posted in Boiler Advice Forum on UK Plumbers Forums.
W
wild nomad
Hi there,
I am trying to diagnose a problem with a Remeha Avanta Plus 28C combi-boiler and have a problem with the hot water. When it first turns on it's good and hot, however, after a few minutes it cuts out and the water turns cold. The central heating is fine.
The pump is fine and the pressure in the system is about 1.5 bar which is OK. Checked the expansion vessel and that's fine also.
There is no manual and no scale inhibitors or Mangna Clean have been installed. No idea as to the age either. Wondering if it could be the plate heat exchanger getting bunged up.
Anyone have any bright ideas of what this could be?
Thanks in advance
Mike 🙂
Reply to the thread, titled "HOT WATER KEEPS CUTTING OUT? - Remeha Combi-Boiler E7 error" which is posted in Boiler Advice Forum on Plumbers Forums.
wild nomad,
Billy Bob Bob,
