C
coggers
This is my first post so please help
I have a low hot water pressure, when using more than 1 outlet.
My system set up is as follows:
Arison e-system boiler
Santon Unvented indirect cylinder
Flamco airfix P 100l
Aqua system pv 18l
I have checked the pressure in my Aquasystem pressure vessel and I am getting zero.
The system pressure seems good, around 3.5-4bar, but then drops off significantly when running hot taps around 1.5bar.
Any ideas anyone
As croppie has stated you need a qualified person to look at the system. Your set up requires annual maintenance to keep it safe and working correctly so why not get a unvented cylinder service booked in with a g3 engineer, they will identify any system issues when they do the basic tests required.
