View the thread, titled "hot water probs" which is posted in Bathroom Advice on UK Plumbers Forums.
N
nigelh
pump fed system with cylinder
hot water is only getting lukewarm all of a sudden over night on whole system
any ideas or solutions
many thks in advance
what hot water system do you have? open vented, unvented, thermal store, solar for example. do you have a system blending valve? is it a y plan, s plan ?
check stats on cylinder and boiler are set correct, have you tryed the heating? if that gets to temp you can probably rule the boiler out and look towards the controls.
Reply to the thread, titled "hot water probs" which is posted in Bathroom Advice on Plumbers Forums.
