View the thread, titled "hot water starts then stops" which is posted in Bathroom Advice on UK Plumbers Forums.
J
jmg1676
hi , i have a hot water system with a flow sensor the pump is a wsp gold star pump which turns on and off ok with the sensor seems to work ok spins ok when tested gently with a small screwdriver ,when you turn on the hot tap you only get hot water 4 about 20 seconds then gos cold boilers working ok
??????? thanks
Reply to the thread, titled "hot water starts then stops" which is posted in Bathroom Advice on Plumbers Forums.
