A
aero
I recently noticed that there is water coming out of the overflow on the side of my house. After a bit of inspection, I see that the hot water storage tank is overflowing into the hot water header tank (which now contains extremely hot water). I also see the the ball valve in the header tank is leaking, adding additional cold water to the header tank.
If i fix the ball valve, does that solve my problems? or is there a poblem with the storage tank as well? (i have just moved into the house and there was no problem with the overflow when i moved in, so i suspect that something has deteriorated - probably the ball valve?)
