View the thread, titled "Hot water tank top outlet fitting" which is posted in Bathroom Advice on UK Plumbers Forums.
G
Greengti1
hi all,
i am am looking at fitting a surrey flange to the top of my hot water tank.
The current arrangement is a 28mm pipe going into a 31mm outer diameter right angle bend which goes directly into what must be a 33mm(?) compression fitting outlet on the tank. I have searched and searched but can't find any reference to a hot water tank inlet fitting which can accommodate a 31mm pipe.
is this unusual, has anyone seen this arrangement before?
The surrey flange I have had a 22mm side outlet and 28mm top outlet. Do you think the tank to fange connection will fit?
also do you think the pipe looks copper or iron?
Hi
thanks for the reply. I think I might have mislead you with a poor pic. The pipe you can see is a 31mm outer diameter femail right angle joint which the 28mm pipe slots into. The new pic shows where the 28mm pipe goes into the right angle joint which goes into the compression joint pic. The use of a 31mm outer diameter joint going into a oversize compression joint is what's confusing ..,
cheers
Adam
You have a 28mm bent cylinder Union. With a 1inch adaptor. It's a union, not a compression fitting.
You would be better installing an Essex boss to the side of the cylinder. These need drilling in! Be confident, or get a plumber. 1 hour job.
Reply to the thread, titled "Hot water tank top outlet fitting" which is posted in Bathroom Advice on Plumbers Forums.
