View the thread, titled "Hot water temp" which is posted in Bathroom Advice on UK Plumbers Forums.
duarab
Hi, what temp should hot water be set to on combi boiler? also if the flow is to high for the requested water temp does turning up the temp settings have any effect or does the boiler automaticaly use full power to try and achevie the temp? my boiler is a ideal combi logic+
Do not forget that the you may need to adjust things in the winter when the water off the cold main is significantly colder and the bioler
requires a temperature lift beyond the boiler capacity for a given flow rate.
centralheatking
Reply to the thread, titled "Hot water temp" which is posted in Bathroom Advice on Plumbers Forums.
