View the thread, titled "Hot water temperature" which is posted in Plumbing Advice for Any Other Country on UK Plumbers Forums.
sdowen
How can I increase the temperature of the water coming through the taps in my bath?
The water seems to be at best warm to hot and I rarely need to add cold water for baths.
By contrast the water coming through the taps in my kitchen is sometimes scalding hot.
My boiler is a Vokera 20-80 Flowmatic, the temperature control for water is turned to maximum and the water pressure is in the recommended range between 1 and 1.5 bar pressure.
Any help much appreciated?
Simon
You need to adjust the flow rate of water through the boiler. It tells you how in the installation instructions or you can fit an external flow restrictor.
Mike
Upvote 0
Reply to the thread, titled "Hot water temperature" which is posted in Plumbing Advice for Any Other Country on Electricians Forums.
