scots_jon
Apologies if this has been asked before, I did try a search.
We have juts moved into a house that has a Baxi 100E gas fired boiler feeding the central heating and hot water cylinder. The hot water is always far to hot, dangerously so. I have checked the valves and these seem to correctly select between the heating and hot water loops.
There is a water thermostat on the side of the cylinder in a cutout in the insulation. This seems to act only as a switch, i.e. with it set below 20c the water never gets hot, with it anywhere above 20C the water is far too hot. The thermostat seems to work because I can here it click when the knob is turned and that in turn controls the hot water valve. However even with the tank brim full of very hot water the surface that the thermostat sits on is never warm! So it seems the thermostat isn't getting to detect the water temperature. Further evidence is that the there is a immersion heater in the cylinder (not wired up). The 'stat on that clicks when turned to about 75C, while the 'stat in the cutout on the side of the tank is still clicking at 20C and the tank is cool behind it.
Is the tank possibly twin walled??? is the side 'stat just in the wrong place? I can't think what on earth is going on.
Many thanks in advance for some help.
Cheers,
Jon.
Cheers,
Jon.
