View the thread, titled "Householder here, pls help, downstairs rads cold, enginineer stumped after power flus" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Re: Householder here, pls help, downstairs rads cold, enginineer stumped after power
Worcester GReenstar HE boiler with hot water cylinder in airing cupboard with grundfos 15/60 pump.
So, problem is that downstairs rads suddenly stone cold from about a week ago. have bled rads, no change, turned them all of upstairs to try and divert downstairs, some became warm, but certainly not hot, some still stone cold.
History - boiler changed to Worcester GReenstar He around 7 yrs ago she we moved in and some rads added/ renewed. Two rads at back of house still never heated that well so around 15 months ago decided to try and fix that. heating engineer said problem was that Grundfos pump too small, changed from 15/50 to 15/60. Since then all rads wonderfully warm till around a week ago, as above.
New heating engineer came yesterday, didn't think pump as only 15 months old. Power flushed today, said got some heat to each and every rad in the flushing process. However once system refilled and balanced, no change, downstairs rads still cold.
On telephoning Worcester for some help he says they told him should not have 'extra' grundfos pump in airing cupboard as this will 'compete' with pump in boiler and they will be fighting against each other, causing both to fail quicker than they should (is this correct?).
Therefore engineer now suggesting renewing boiler pump and taking grundfos pump out, although he did say he tried running grundfos pump only today, still no heat to downstairs rads, and then boiler pump only, and, again, still no heat to downstairs rads so surely this unlikely to solve problem?
I am wondering if We may just need a new grundfos pump and a bit cautious about just doing away with this pump as the new grundfos 15/60 15 or so months ago gave us fully hot radiators all over the house!
I would be grateful for all and any ideas as concerned that I am going to be spending a lot of money trying to fix this without a correct diagnosis as to what is actually causing the problem...
Thanks Tom, would be great if you could spare the time to read rest of post, first one just wanted to post as have typed out about 3 times and kept saying I wasn't logged in ....
The worcester engineer is right you can not have two pumps on the same system they will compete against each other. Sometimes a pump appears to be working but the impellors are damaged or worn. There may be a closed off or partially closed valve in the system. Sometimes gate valves can be a problem the stem snaps. Your system may need balancing water will always take the easiest route. As a rule of thumb half close the upstairs lockshields and fully open the downstairs ones. If it starts to work balance the system using a thermometer.
are upstairs rads as hot as normal ? you dont have a room stat on both floors is your hot water hot feel the pipes but be cateful they could be very hot do you have a bypass on the system
It does sound like the pump on the boiler. also maybe blockage in system.
A bit worrying that the engineer needs worcester to tell him that there shouldn't be a extra pump fitted. That needs to be cut out but why was it fitted in the first place.
Thank you to everyone that has replied. Take the point that the engineer should know you can't run two pumps .... But he was not the one that fitted new grundfos 15 months ago at a cost of £ 360 ... However, it worked and all rads hot for first time!
Sorry if this is a daft question, I am a woman with very limited knowledge ... Do all boilers have a pump in them? Surely not, otherwise why would you have a pump in airing cupboard which so many people seem to have?
one more thing, if it helps with the detective work. Now that we have heating on '5' on boiler, it normally reads about 75 then, but keeps fluctuating now, going down to say 35 and then coming back up ( may have always done/. Should do this, but trying to spot everything now)! Would this have anything to do with pump on boiler?
So, most of you would agree pump in airing cupboard needs to go and we should be relying on pump that is in the boiler to pump the heat round whole house ?
Also, if possible blockage, how do we remove - isn't this what the power flush is for?
Thanks for all your advice.
And can someone give a quick explanation of what bypass is?
on hot water only does the temp stay high on the boiler once it has reached temperature
a system boiler has a pump inside it. a heat only boiler does not and you normally find the pump in the Air cupboard.
a bypass is a spring valve which is set to open at a adjustable pressure to make sure the boiler always has a min flow rate through it. Some boilers have them built in, some need an external one on the system, some will need/require both.
a powerflush is to clean the heating system, it wont always remove partial blockages especially bad ones.
Maybe the 15 month old pump is blocked or sludged up, did the chap check when power flushing?
Where did he powerflush from? Maybe the debris was pushed into the boilers pump!
Theres your problem ^^^ all rads hot for the first time. When were they not hot.
there is a circulation issue, pump, sludge, blockage maybe.
Thank you everyone. Tom, I will have to check when hot water only on and will let you know.
Gas Safe - power flush was done from hall radiator.
A Wheating - thanks for explanation. By heat only system you mean heats rads only and not hot water?
Plumber 0808 - so from what you say perhaps pump on boiler was not so good when grundfos one was fitted so grundfos 'extra' pump fixed the problem for a while until the use of both, one on boiler and grundfos caused one or both to fail.
So to recap - would next step be remove grundfos and replace boiler pump?
How do you locate the sludge/blockage and remove ...
Obviously my concern is that I have spent money on power flush and now need to spend some more and worried that we are going to go through a few things that are not solving problem.
Also, engineer said grundfos pump was working otherwise radiators would not heat up upstairs ... But he did also say he took silver screw off and it was working ?
I'm pleased its giving you a laugh guys, and its certainly wrecking my head .... But please take pity and give me some proper suggestions as to where to go next ... Or if any of you are near to South London ...
not always the case spindle in the pump can spin even though pump aint working or csn spin slower
put your hot water on how is the temp on the boiler does it rise regular or rapid
The 2 rads that struggled before are either, undersized pipework or sludge is restricting the flow to them. by fitting the second pump your curing a problem with another problem. Remove the second pump have a new pump fitted to the boiler.
Sometimes a power flush is not the answer as some systems are too far gone.
First step should be to remove the external pump, unless you have an extremely large system I can't think why you'd need an extra pump. Just because it is rotating does not mean it is working, the fins could have snapped on the impeller. The external pump could actually be causing a restriction in the system.
The radiator he powerflushed from, what size is the pipework supplying it? Drinking straw sized or larger? If it is drinking straw sized (8 or 10mm) the powerflush will have been next to useless.
Plumber 0808, thank you. I understand what you are saying, but we were warm once the new grundfos was fitted! Will try with new pump to boiler then. By 'too far gone', does that mean replacing system, or is there something other than power flush to remove sludge.
Tom - hot water only been on for about an hour. Boiler temp seems to be fluctuating between 75 down to around 63 ...
you needsomeone to check the resistance on the sensors to start with k
Reply to the thread, titled "Householder here, pls help, downstairs rads cold, enginineer stumped after power flus" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
