Feb 10, 2022
perth
DIY or Homeowner
Hello All,
One of my mixer taps is dripping. Quick research tells me to replace the washer. So I prise off the top of the tap, remove a screw, then lift off the tap handle to be faced with what you see in PIC1. I am guessing I need to remove the collar with the groove ?
Can anyone please tell me -
1. The brand of my tap
2. What type (with recommendation) of tool I may need to remove the tap
3. After managing to remove the collar on the tap, will there be a washer or a cartridge at the bottom.
I have three of these taps leaking in my home so If I can nail this job then I am in good shape for tacking the others.
Thanks folks !
"We've had a tough day; we've tangled with a little pipe and porcelain. Now it's Montrachet Time!" - Frasier Crane.
I don’t know the brand of tap, but one would presume that the grooved collar does come off. A wide mouth adjustable spanner or flat jaw grips should work.
1K
UK Plumbers Forums
Deleted member 120897
1K
UK Plumbers Forums
