How do I service and repair this diverter?
View the thread, titled "How do I service and repair this diverter?" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
On a tight budget, but I'm handy. The diverter leaks both ways, it has a little lever to flip back and forth. Either way, the shower is getting water when you don't want it to, or you're getting lots out of the faucet but not enough pressure from the shower. I tried to pull the stem, but I can't find what's the appropriate way to deal with this sucker:
Found out the diverter valve just pulls out, there was a bung (I don't know what you call it) that I unthreaded already, and then I just made a makeshift puller with a socket, then a washer and tightened down a long screw to pull the valve out.
Reply to the thread, titled "How do I service and repair this diverter?" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
captaintrav,
captaintrav,
