View the thread, titled "How do I take out cartridge from mixer tap?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Kitchen mixer tap, took off handle, no idea how to take out cartridge/valve leaking, on the back there’s a hole for an alley key, doubt that’s it.
Looked at videos on YouTube, does make me wonder to put a rag over tap with a wrench to turn anti clockwise, but slips, I don’t know, run out of idea, help please?
more than like a cloth over the cover and pair of grips but dont squeeze too tight you may damage. do you have the cartridge. if not then why not just go with a new set of taps. from a good make
Cone shaped chrome shroud will probably unscrew. Try using a rubber glove or boa type rubber wrench to get better grip without damaging chrome. Will almost certainly unscrew anti-clockwise looking down at end of spindle.
This bit will unscrew mate to give you access to the cartridge.
Please like this post if you found it helpful.
Reply to the thread, titled "How do I take out cartridge from mixer tap?" which is posted in UK Plumbers Forums on Electricians Forums.
