View the thread, titled "How do you change the washer on this type of kitchen mixer tap?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi All,
Kitchen mixer tap (see image) is dripping and it's driving me nuts! I can't find a good enough description of the type of tap it is to find a link on You Tube and work out how to change the washer.
Any links or generic advice on what needs to be done to change the washer (after I've turned the water supply off) would be appreciated.
Thanks.
Heads have little grub screws in side, heads pop off and expose quite standard valves.
These are 1/4 turn ceramic cartridges and you'd be best to change them but can be awkward getting the right ones.
If it were me I'd replace the whole tap as its just a cheap one
The tap appears to be a Hapilife model "Hapi-03Z"
I think it has ceramic cartridges in it, not traditional washers.
I suspect if you can unscrew the chrome 'collar' under the lever handle, it will pull off, complete with lever, when fully unscrewed.
You will need to find a pair of suitable cartridges, investigate why the current ones are leaking, or buy a replacement tap for £24.99!
you were quicker off the mark, Knappers!
As an Amazon Associate we earn from qualifying purchases.
Thanks for the info - found the screws you mentioned. Going to take up your advice regarding getting a replacement as the spout is loose and I don't need quality taps at the moment.
Reply to the thread, titled "How do you change the washer on this type of kitchen mixer tap?" which is posted in UK Plumbers Forums on Electricians Forums.
