plumberdarren
Hi guys
I was called out at 7pm last night (Sunday) by my sister in law as the flat next door had water coming through the ceiling, i went straight round and found that the bloke in the flat above was so drumnk he'd ripped the toilet and pipework out of the wall causing the flood. i quickly cut the pipe live and put on a push fit cap as was quiker to do that rather than get ladders and go into the loft to isolate. I then got the wet vac out and hoovered up the water upstairs and downstairs, i also put some holes in the ceiling to drain the water away.
In summary it was a sunday evening call out to stop the leak, cap the pipe and clear up the water. I was there about an hour. The in surance company now require an invoice how much do you think is reasonable do you think ?
