Smcart5
I must have the worst waste pipes around, unscrewed the wastes under the sink to find the source of the smell and found most of the washers had degraded to the point they had broken in several places (explained the leaks that started not long ago)
Main connection to the soil stack that runs from kitchen-bathroom-stack was in an unrecognizable size until i measured it, it had thick black chunks of something (source of the smell) that i scraped out with a spoon and it started leaking which i remedied using a gel that sets in water, repaired all wastes with ptfe and new washers.
Had to plunge the sink in the bathroom to dislodge a blockage causing a slow draining waste (the traps had been sealed up with some kind of putty 😡, doing that dislodged the plastic fitting sealing the waste connection on the underside of the sink so that needs repairing now 😱
Do you guys find that more goes wrong out on jobs than you expect?, this is all from the place i moved into not long ago.
