How to access taps behind a P shaped shower bath
View the thread, titled "How to access taps behind a P shaped shower bath" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
I'm about to install a P shaped shower bath into a small bathroom. However I've noticed that with the bath in place it's not possible to reach under the bath to the pre drilled tap holes. Because of the circular shape there's also no line of sight to these either making it very hard or impossible to reach with a spanner.
So if I were to install the bath like this I'm wondering if it's possible to remove the taps without ripping out the whole bath?
One option I'm considering is to cut new tap holes in the centre of the rim. But this means filling in the old taps somehow and I'm wondering if that's necessary. The bath was designed this way with the pre cut holes so presumably there should be a way to unscrew the tap nuts from underneath?
So I'm interested to hear other's thoughts on this problem.
Welcome to Plumbing!
If you cannot reach the taps with your neck broken and your face squashed against the side of the spikes of fibreglass, with your arm scratched and sliced by it, then you will struggle to get them out, yes.
Could they be reached through the wall it will sit against? (access panel).
You could take the bath out if you install it with that in mind.
You could re-drill new holes I suppose but you need to look at where and how they will be for strength.
You could fit it and look at it that it's not really your problem. Presumably you didn't choose the bath.
Yes, that would be my answer too, if it’s not practical to access through a Partition Wall, Flexible connections are not ideal, especially on an unsoftened supply in a Hard Water Area, but often the only solution to your customers design preferences.
As to the not my problem response, I will treat that with the contempt it deserves, if you’re going to do the job at all, Do It Right !, and even if you think it will be a Fit and Forget, one day someone will want it fixed, possibly the New property owner, and you might be the poor sod they find in the yellow pages or online 😂.
Installing a P-shaped shower bath in a small bathroom presents a challenge when it comes to accessing the pre-drilled tap holes. The bath's shape and the limited space, as shown in your diagram, make it difficult to reach and tighten the tap nuts using standard tools. To address this, you could use specialized tools like basin wrenches or telescopic spanners, which are designed to work in tight spaces. Alternatively, cutting new tap holes in the center of the bath rim could offer easier access for future maintenance, although this would require covering the old holes with decorative covers or blanks.
If you proceed with the current tap hole positions, using flexible tap connectors might simplify the installation and maintenance process. For future tap removal, ensuring there's a removable panel or access hatch could be beneficial. While cutting new holes isn't strictly necessary, it might be worth considering if you're concerned about accessibility. Consulting a professional plumber could provide additional solutions tailored to your specific setup.
Reply to the thread, titled "How to access taps behind a P shaped shower bath" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
horbes,
opplumbinghub,
