View the thread, titled "How to drain an EcoTec 28 combi boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
C
Claire
I have a Valliant ecoTec Pro 28 combi boiler. Please could someone let me know how I drain the system to fit a new thermostat to one of the radiators.
I have looked on the boiler and cannot see a drain valve. The instruction manual says that it should be located 'on the lowest point of the system.' Could someone help?
Thanks.
has the boiler got isolators on the feed and return to the CH circuit?
If so flick them and it will create a vacuum
Then crack the nut on the rad and a few drips might pop out but thats in and away you go
if not you will need to drain via maybe one of the low drain cocks often next to a rad valve
Are you sure it needs draining? Might just need a new TRV head? Or, if the valve itself, sometimes a knock is all that's needed to free.
Edit: Although I know this doesn't answer the question. Apologies if the OP has already thought this through....
Claire, do not do as Tom says unless you are confident and understand what he means and know what to do quickly if it goes wrong.
I think your best bet is to drain it down , if there is no drain then get one fitted.
Reply to the thread, titled "How to drain an EcoTec 28 combi boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
