How to fix leak with too much ptfe tape
View the thread, titled "How to fix leak with too much ptfe tape" which is posted in UK Plumbers Forums on UK Plumbers Forums.
A
Adam davis
Both Tiny leak on bot new fits on the metal nuts. Did i use too much ptfe tape. I used 2 wrap arounds. The nuts won't tighten anymore. Could i remove the exposed ptfe tape and if so would the nut then continue to tighten and is this a ok thing to do. I should have used 1 wrap around i know now.
Reply to the thread, titled "How to fix leak with too much ptfe tape" which is posted in UK Plumbers Forums on Plumbers Forums.
Adam davis,
king of pipes,
