View the thread, titled "how to fix this leaking tap" which is posted in Bathroom Advice on UK Plumbers Forums.
~i cant find any way of dismantling the tap ,opening the top of the taps or anything. it says visions on top of the taps. any help would be greatly appreciated thank you
Most likely either:
1. The topmost chrome cap unscrews from the gold coloured band. OR
2. The gold coloured band unscrews from the larger chrome shroud on each tap.
This should reveal a screw which, if undone, allows the top of the tap to be removed. The body of each valve can then be unscrewed from the body of the tap with a spanner.
Most likely either:
thank you so much. turned the water off at the stopcock ,then tried what you recommended and it worked a treat. new washer for about £1 and all fixed. very many thanks.brilliant
Reply to the thread, titled "how to fix this leaking tap" which is posted in Bathroom Advice on Electricians Forums.
