View the thread, titled "How to identify dripping tap." which is posted in UK Plumbers Forums on UK Plumbers Forums.
Turn stopcock off. That should stop cold.
If you’ve a combi boiler, turn it off, the cold stopcock will also stop the hot. Open kitchen tap hot and cold, then open upstairs bathroom hot and cold. Water will stop after a min.
If you’ve got a hot water tank. If an unvented/mains pressure, same as above.
If gravity, fed from loft tank, you need to isolate the cold feed to the cylinder. Either valve near cylinder, or in loft on cold feed to cylinder pipe.
Thanks Timmy. We're a bungalow so ours is a totally closed system, heated from an Air Source Heat Pump and pressurised by the mains water pressure I guess . Cylinder in airing cupboard.
If I turn off the mains I guess it will take quite a while for the system to de pressurise and stop flowing.
If I'm going to do that I will try to fit stop cocks in each tap supply line but they are very tight against the back of the fitted kitchen cupboard they're in.
Or use these if your new tap comes with swivel flexis
Thanks everybody for the help, job done. The problem was that the mains shut-off valve was sticking, not shutting completely. Moved it on and off a few times and it sealed properly.
With water off and pressure released, installed two isolating valves in the kitchen taps so can now repair one or tother!
Can you turn off the supply to just the cylinder, then open hot tap to drain hot system.
If it continues to drip, its the cold.
Either way, i always replace cartridges in pairs.
Good job, in future, use full bore lever valves with a packing nut. Whenever I have to use these screwdriver valves, theres a 50/50 chance it will leak and need replacing.
Reply to the thread, titled "How to identify dripping tap." which is posted in UK Plumbers Forums on Electricians Forums.
