View the thread, titled "How to refill the boiler - Vaillant EcoTec Pro 28" which is posted in Boiler Advice Forum on UK Plumbers Forums.
desibuoy
I don't know how to do this on the boiler. I've googled quite alot and even on this forum and everyone says there must be a Flexi loop with 2 valves or even 1 and that's it.
My boiler only has 1 black Valve. I've turned it fully - no water, I turned it a quarter and still nothing.
Even tried to adjust the Bar thing using the buttons but it's not increasing it.
I've never had problems filling the boiler in my other properties I've rented.
You can see some pictures here not quite clear (S*** Phone) lol.
https://www.dropbox.com/sh/qdbyoyxfp1c7nqn/AACEmmsBi0Z8iXXEuEVbvJgCa?dl=0
The Bar is at .7 right now.
The connection for loop are in the first pic, you just need to find loop and connect it up. Perhaps call landlord
I asked my landlord and he doesn't know.
said he will look into it, had a problem with the plumber or something.
btw here are clear photo's
Also moved the washing machine to try and find the cold water pipe and found a valve i tried turning it and nothing. (picture added to Dropbox)
and had the black valve running parrarel to the pipe underneath the boiler.
As above the flexi is not connected to the too taps to re pressurise the boiler, call you land lord to get a plumber out, should have it sorted in 15minutes
Hi Plumben,
The house was very cold so I decided to at least warm up for a bit and just 20mins the pressure shows 2.2??? I thought it was only the plus that were automatic. I've let the landlord know too.
Thanks again
And thanks to dancinplumba.
Reply to the thread, titled "How to refill the boiler - Vaillant EcoTec Pro 28" which is posted in Boiler Advice Forum on Plumbers Forums.
