If you are not sure turn the small one off (across the pipe) under the pressure reducing valve.I have noticed water dropping intro the tundish of my Megaflo Unvented cylinder. I believe I need to replenish the air gap.
Do I need to switch both the levers/valves off in the pictures attached before starting the process?
Thanks in advance.
but it should just be the the one labelled "cold water mains isolation to hot water cylinder".
Open the hot taps (lowest one such as bath) wait until the water stops running then twist the T&P knob, if your cleaver you might get it balance in the open position before it clicks over on the cam, if not you will need to hold it. This will allow the air in & the water out of the tap . You may need to keep this going for 10-15 mins until the water stops running & the air gluging-in.
Turn T&P to closed, shut hot taps, open up the isolation valve refill the system, open hot taps to vent the air in the pipes.
Most important dry out the tun-dish & check that water has stopped dripping & again in a day of 2, if it is still wet after two days then you will need to call an Un-vented plumber to check over the system.
Did you open up the T&P safety valve this is the fitting screwed into the side of the cylinder, on the right hand side, close to the top. Did you hear the air going in? as it went in the water would have come out of the downstairs hot tap, if the bubble was completely lost it would likely take a min of 10 - 15mins for all the water to drain & be replaced with air.Thanks Chris. So just this one in the picture then?
[automerge]1567859226[/automerge]
I have given it a go. Not sure if I fully completed the process correctly though but made sure that all hot water had stopped flowing from the downstairs open hot water tap before turning the cold water valve back on by the cylinder. There was rush of pressure when this happened, I presume this is normal? After about 10 seconds this stopped. I have turned some taps on around the house and no issues with pressure. During the whole process there was very little water flowing through the tundish.
Is it possible to do this process wrong and cause other problems or will it just solve the issue?
The outflow via the tundish stops after about 10s but that's the start of the process not the finish! You need to keep the valve open for ca 15 minutes while your lovely hot water runs down the drain via the tap hot tap you have opened, which should be at a height below the tank.There was rush of pressure when this happened, I presume this is normal? After about 10 seconds this stopped.
Reply to the thread, titled "How to Replenish Air Gap In Unvented Cylinder?" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
