A
ahoythere
Firstly, may I say this: there is quite a bit of info available on the web - including a YouTube video - about how to top up the pressure in a heating expansion vessel (and I know how to do this), but nowhere can I find any information about how to top up the pressure in an expansion vessel which regulates hot water pressure (to showers, taps etc). I am hoping that this forum will shed light on the subject and that the world will thank me...and you! 🙂
To my problem...
I'd like to increase the pressure to my shower. My house is fitted with an unvented heating system. There is a white 'Varem' (Extravarem 12 litre) expansion vessel located just above my hot water cylinder (picture attached). [To avoid confusion, there is also a red expansion vessel fitted near the hot water cylinder which is not the subject of this post].
On the top of the white expansion vessel is a Schrader valve. When I depress the valve, no air comes out which suggests that the cylinder needs recharging. The reason there is no pressure is that I think I let the air escape (doh!) with some cack-handed attempts at trying to top up the vessel. The sticker on the vessel says that the cylinder should be precharged to 3 bar and the max working pressure is 8 bar. I am reasonably confident that there is nothing at fault with the expansion vessel or the Schrader valve.
Please could someone explain how I go about recharging the expansion vessel and how much pressure to put in it. When I tried to do this earlier, I closed off the two red handles marked 'Hot Water Stop Valve' and 'Incoming Water Main Stopcock' (see picture attached), opened all the hot taps in the house, but still found it impossibly difficult to pump air into the vessel. I'm obviously doing something wrong!
I have taken a couple of photos showing the expansion vessel and the hot and cold cut-off valves and would be very grateful for expert advice.View attachment 4485View attachment 4486View attachment 4485View attachment 4486
To my problem...
