Ok I'm after all your advice on this one! I was called to one of the above boilers that had locked out! The clear oil line was full of air, I bled it through and left it run for 10 mins. It slowly filled with air again! I've had no experience of these boilers so I called HRM and they said it was the non return fire valve not functioning rite! So I order done and change it, but after a week the same problem persists! It's the only wall star in our area! I can't see as it's a hole in the copper line cause there would surly be an oil leak! Any advice pls
