Guest viewing limit reached
Huge rayburn fuel bill
View the thread, titled "Huge rayburn fuel bill" which is posted in UK Plumbers Forums on UK Plumbers Forums.
N
Nathan Folland
Hi all
Im after some advice regarding my mothers rayburn .
I think its a rayburn supreme (sorry i can't give a more definitive answer , she has just been around worrying about it so not had a chance to go and get a serial number ) .
Basically it uses huge amounts of oil (1500 litres in 6 weeks ! ) . It runs the heating and and she also cooks on it .
We have been told by the guy who services it it was once a solid fuel rayburn that has been converted to oil . She has got to the point now where she can no longer afford to run it and no engineer seems to keen to get involved .
last winter she ran out of oil in january and she lives on the highest point of dartmoor in an old cottage where the temperature can hit - 15.
money is a bit of an issue so I have been looking at second hand rayburn 480k but there seems to be quite a few issues surrounding them . so my question is what in your opinions would you say is causing the inefficiency with the limited info i have given and what would be your choices of a good 2nd hand model .
Any advice would be gratefully received .
Thanks in advance
Nathan
An obvious question is to ask what the insulation is like? Also many older customers I know run the heating 24/7 at 25degC, how does she run the heating?
Even so, it seems massively excessive.
a normal rayburn solid fuel conversion throws out around 7kw and uses around 13cc a minute on high. your figures of 1500 litres in 6 weeks equates to some 25cc a minute, somethings wrong there, more like its been syphoned off, or is leaking away. has anyone inspected the tank, is it a rusting metal heap? What ever you do avoid rayburn nouvelles, 30kw output with 50cc plus fuel rate per min!!!!! My other query is how a solid fuel conversion can mange HW, heating and cooking?
youdbe better putting in a decent oil boiler and a small 208/308k rayburn for cooking if she still wants one.
1500 litres in 6 weeks sounds like a leak or fuel theft.
However the oil conversions are a bit of a fudge - the combustion chambers aren'r really designed for oil and you are never going to come close to the kind of efficiencies you would get from an up-to-date model such as the Rayburn 680KCD. We have the previous version of this fitted in our house (The 480KB), and it is very economical.
Reply to the thread, titled "Huge rayburn fuel bill" which is posted in UK Plumbers Forums on Plumbers Forums.
Nathan Folland,
WHPES,
