I need help finding toilet seat (URGENT)
View the thread, titled "I need help finding toilet seat (URGENT)" which is posted in Boiler Advice Forum on UK Plumbers Forums.
hi, as the title suggests i need help finding this type of toilet seat, i ordered one but completely forgot to check distance between fittings and it didn't fit. The distance between the fittings for the toilet is 260mm and its for a wall hung toilet. i can't seem to find
anything similiar.
Go to a plumbers merchant and ask them to source you one. You'll pay a premium for it but the alternative is the same as anyone else, just a long slog on google trying to find one. I have absolutely no interest in doing that for nothing for you as its not at all interesting to me, I expect it will be the same for most others.
If you do go asking for help give them a drawing with dimensions;
  • distance between fixings
  • distance from fixings to the front lip
  • distance front to back of the opening
  • distance from left to right of the opening
  • distance from left to right of the entire toilet
And rotate the image because its difficult to look at upside down
Not really fb, look closer. The manufacturers name is embosed on the underside of the seat lid, otherwise no chance I would've bothered.
wow thats really costy, that was gonna be my next questions is there one for cheaper, or is anyway to refit this sit back or something with similiar top fixings.
The seat is a non standard shape, by the time you Sod around trying to find a good or ill fitting match or bodge some fittings you might as well cough up.
You can get seats with adjustable hinges that should the fit the pan but the seat wont be a great match or go down to a merch as suggested and see that they can find for you.
You can get a generic one for about £30-£35 from merchants off the shelf that will fit but not match the exact shape- if you’re not bothered too much just do this.
i went to quite a few, they weren't able to find it
Either buy the correct one at the higher cost, or put some effort in yourself on the internet, or accept a generic square one that doesn’t quite fit properly.
They are your choices - this is now a boring thread!
Reply to the thread, titled "I need help finding toilet seat (URGENT)" which is posted in Boiler Advice Forum on Plumbers Forums.
iphone11s,
Ben-gee,
