A
alexterry
I'm doing a job, boxing in a combi boiler and have had concerns about how much ventilation it needs. Its a vaillant eco max combi boiler and have spoke to the guys at vaillant and was informed that as its a combi boiler it doesn't need ventilation, However, they did say there needs to be a minimum of 500mm from the front of the boiler, to the doors that access it for servicing reasons. The problem is this can't be done as the boxing will be massive and will just look utter rubbish in the area it is in. (is this a strict guidline that needs to be stuck to??)
My girlfriend not long ago had a new vaillant combi boiler fitted in an existing boxed in area with door and the space between the boxing door and the boiler is only 200mm and it was fitted by gas safe engineers obviously.
On this job, i can only have a gap of 100mm max and i just can't see why that if its not a ventilation issue and only for servicing reasons, why i can just put some doors on it, and removable shelves below so that it can easily be got at if i ever needs servicing.
the guy i'm doing the job for has left it to my discretion so, obviously i don't want to get this wrong.
Any help would be appreciated.
cheers.
cheers.
