I really need help with kitchen sink plumbing
View the thread, titled "I really need help with kitchen sink plumbing" which is posted in UK Plumbers Forums on UK Plumbers Forums.
B
Brooke
Hello I’m not going to explain this very well but I will try my best. I’m planning on installing a kitchen sick by myself with no plumbing experience. I will be going from a double sink to a single basin. The part im having trouble figuring out is how to put the pipes back together with the garbage disposal now being on a middle drain. My current plan now is to cut the length of the horizontal arm pipe to be shorter to compensate for it moving from the right to the middle of the sink opening. I would then use a 90 degree elbow and a straight coupling to attach to the ptrap. Is this something that makes sense and would work? I’ve mostly seen disposal pipes that attach to the disposal and then go down rather than across like mine would but I can’t figure out how I’d attach that type of drainage pipe to the pipe in the wall. Really I just want to know if my idea will work or if I’ll make future plumbers cry. Thanks!
Hi Brooke, can you upload a photo, as this would be better for us to understand your proposal? Sound like you need to move the disposal unit.
Reply to the thread, titled "I really need help with kitchen sink plumbing" which is posted in UK Plumbers Forums on Plumbers Forums.
Brooke,
Deleted member 120897,
