View the thread, titled "ideal esprit 35 ,heat exchanger knakerd,condensate running constantly 3litres perhour" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
markmonty
I have a combi boiler which is losing pressure rapidly, condensate is losing 3 litres of water per minute, I phoned ideal service department and they tell me main heat exchanger is knakerd, however I turned off the cold water supply going into boiler so it is effectively only doing heating now and it is working ok ,obviously without giving out any hot water to taps e.t.c , I find this confusing as it wasn't working atall before I shut off cold water inlet valve, it now seems to not be losing water pressure either, any suggestions as to why this might be , im confused.com:annoyed:
Re: ideal esprit 35 ,heat exchanger knakerd,condensate running constantly 3litres per
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - http://www.ukplumbersforums.co.uk/users/8668/ or Redsaw - http://www.ukplumbersforums.co.uk/users/2718/ who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competetence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
Reply to the thread, titled "ideal esprit 35 ,heat exchanger knakerd,condensate running constantly 3litres perhour" which is posted in UK Plumbers Forums on Plumbers Forums.
