M
mark72
Hi All
As part of an electrical install, I've been asked to wire a couple of commercial boilers in synchro. The boilers are Ideal Evomax and they have the shunt pumps below, and the external controls are 2 port valve for hot water, Central heating pump (But no 2 port valve on the heating), programmer, R/s and C/s.
So I'm intending to wire as an S plan and connect shunt pumps direct to boiler, but the part I can't understand is where the CH pump is connected.
can I externally power the pump through a contactor and switch the contactor from the boiler?
