hi all , was having a few problems with my heating/hot water when water was put on it would heat up but also heat the radiators up so after bit off searching came up with the 3way port valve so i changed for a new one as when i looked at it when the water was on it was making a buzzing noise, so after it was replaced all was great well for a couple of days and it started playing up again but this time could not get heating or water at all the boiler would fire but constantly show flashing light i had my brother here and while trying to see if could find anything he turned down the thermostat on the boiler its self and it fired up straight away, now since the boiler was fitted a few years ago we have never touched this button it has always stayed on max setting but will not now fire up boiler unless it is set one notch down which is fine the boiler was doing its job heat an water until yesterday when it went wrong again heating is fine but when water is switched on its heating water ok but again the radiators are getting hot, do i have a boiler problem or has the 3way valve gone faulty, i will get a plumber round but due to all thats going on i cant get anyone to come so am just after a bit of advice as to if this is something i can repair myself thks
