W
willing2learn
Hi, having an issue with my boiler. It is flashing up with the fault code 'F' then 'L'. According to the manual this is a failure to light. Just wanna say here that I'm not Gas safe registered butI am a competent plumber.
I've gone through the fault finding list in the manual and so far discovered that the gas valve is getting 240v when called for and you can hear the 'click' from it. But it just doesn't seem to be lighting.
Is there anything else I can try? Just discovered the immersion element doesn't work either! 😱
