View the thread, titled "Ideal icos...No power on display or boiler?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
F
fabio
Long story short.........went to a job (ideal icos) rain comming in through the flue.when i arrived boiler was working ok.isolated the boiler at the fuse spur.took combustion cover off slight rain water inside,dried it off re-fitted c/cover went to switch the boiler back on.....no power there.there is live comming into the boiler from the fuse spur?checked the small fuse on the circuit board...thats ok? baffaled by this.i know the circuit boards are notorious on these things but surely this cant be a coincidence?..............cheers
Had this 1 before, awkward prob, make sure all the leads/plugs are firmly home. Have had to change display board, then next time it was the main pcb.
Worth ringing Ideal 01482498660
i will give them a ring tmoz.i was just thinking if any water had got in any connections hopefuly it may dry out by tmoz?also i was thinking the main switch? i will have to get my multimeter tmoz!! bad boilers.....cheers aggis
Reply to the thread, titled "Ideal icos...No power on display or boiler?" which is posted in Boiler Advice Forum on Plumbers Forums.
