Ideal Isar HE30 Automatic Air Vent replacement
View the thread, titled "Ideal Isar HE30 Automatic Air Vent replacement" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
sgh
Just had someone round to look at my 4 yr old boiler (yes it was a bad choice I know !) after it was leaking, he thinks it requires an Automatic Air Vent replacement & has advised that I ring Ideal. Does anyone know how much Ideal are likely to charge for fitting this ?
Steve
the part only costs around £4, how much they charge, well thats a differant story!!! it takes some one who knows , approx 11/2 hrs to do if you can get to the boiler with out any obstruction, hope that helps
chris.
see if you can find a local guy if its just the Automatic Air Vent replacement , you could well get a better price,
the choice is yours, regards
chris.
Reply to the thread, titled "Ideal Isar HE30 Automatic Air Vent replacement" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
sgh,
cjg,
