king of pipes
Subscribed
Dec 20, 2016
6,156
4,335
113
63
Norfolk
Heating Engineer (Has GSR)
A routine vist to service this boiler a first time for me, turned into a bit of a nightmare as you can see below a small hole had appeared in the plastic flue part that takes the condense away made a right old mess in there i did a temporary repair job and serviced a full safety check it all works and fails safe but it will be replaced soon as possible as i am not happy to leave it as it is . Kop
  • Useful
Reactions: Aquarius
Looks like a bad one but an easy part to change.
Do you clean the brass injector as part of your service?
Not unless it's really bad one bud keep a can of air in the van to give the fan a blow out though
I've not had it on any of my installs? then again they regularly get stripped down so any small issues get sorted , I've had it on a Gloworm cxi when the burner gasket failed took the boiler out completely inside .😱
