View the thread, titled "Ideal Logic 35" which is posted in UK Plumbers Forums on UK Plumbers Forums.
J
Joe@HomeFixx
I only really do Installs so breakdowns is something I need help with, I'm going to go and have a look at an Ideal Logic 35 that is having problems with the hot water. The heating is working fine, however when hot water is needed sometimes the boiler fires up other times it doesn't, the boiler is apparently not showing any fault code.
Am I on the right lines that it may be a flow sensor??
Any help appreciated.
Hi Joe,
Usually the flow turbine sticking not the sensor! It's a common fault on the logics. Make sure you get the right one for the 35kW.
Hi, thanks for your advice, changed the flow turbine and that worked a treat. thanks again.
Reply to the thread, titled "Ideal Logic 35" which is posted in UK Plumbers Forums on Plumbers Forums.
