View the thread, titled "Ideal Logic + F9" which is posted in UK Plumbers Forums on UK Plumbers Forums.
AllyBongo
Anyone know what causes the Logic range to go to F9 fault, MI's just say PCB fault-replace PCB.
Serviced a 24+ Heat today, 1 year old. Carried out the service, fired it up and ran through FGA checks etc. Tidied up and was talking to the customer and noticed the F9 showing. Wouldn't reset, turned off the spur and then back on, fired up fine ran through sequence, pump/fan over run then back to normal. Just seemed to play up once for some reason. Boiler has a condo pump, which the float switch had cut the power to the boiler after servicing, but it fired up once the pump was emptied.
MI's don't give much away..... Just your PCB's gubbed! New one!
Word on the grape vine (in the plumbers merchants), is that they are starting to have problems with these boilers! A fair few have gone down. Whats the warranty on them? Id tell the customer to get Ideal out to it. Sounds like the ISAR all over again!!
7 Years warranty on them, haven't heard back from them yet, hopefully a one off! Read in the Ideal training manual it can go to F9 if it hasn't reset fully. Now trying to remember if I reset it during service........
You tell me a boiler that doesn't have a problem
Reply to the thread, titled "Ideal Logic + F9" which is posted in UK Plumbers Forums on Plumbers Forums.
