Serviced 3 Logic+'s today, two of which when the heating is running or the pump over run is on after demand, the pressure gauge needle is rattling about so much it is actually noticeable from within a 3m range from the boiler. Luckily ones in a cupboard so that drowns out the rattle, but the other is in the kitchen. Anyone else noticing this, any fix's???
Love these boilers, fitted loads, great to install and service. Pressure gauge seems to let them down a bit, due to position I suppose, not great when you need to show an old dear where the gauge is on her new boiler! The extenders are good but should really be supplied with the boiler. Also notice the pressure tends to rise a lot more than other boilers when the heating is on, even on small systems
