Hi thanks for the reply no the heating is not working but the hot water is '0 then C alternate' the manual said: reset which I have but made no differanceC just means the system its calling for heat, 0 means standby. Is the heating working?
If its flashing rapidly then the demand from the system could be intermittent due to a loose wire or faulty component. Such as the timeclock, thermostat or 2 port valve
I doubt its a fault with the boiler itself
Reply to the thread, titled "Ideal Logic+heat 24 (not combi)" which is posted in UK Plumbers Forums on Electricians Forums.
