Dogmod
Hello all, I've just had an ideal logic plus 30 installed in my loft, replacing an existing vented system. The boiler works fine, until you put the front outer cover on, then it fires for a short time and cuts out on flame failure, remove the cover and it works perfectly?
I understand that it requires an air/gas mix to work properly, but why does the front cover stop this? It has a rubber seal around the edge so would asume it was air tight, therefore eliminating the theory it is being starved of air, I always thought the inlet air came down the outer part of the flue?
Can anybody shed any light or offer any advise?
Thanks for reading
Thanks for reading
