View the thread, titled "ideal mini combi" which is posted in UK Plumbers Forums on UK Plumbers Forums.
P4ULT
hi i got a customer with one of these it has an intermittent problem with the hot water running hot and cold any ideas please i dont know much about these
cheers
paul
problem with intermittent faults they have to do it in front of you,if it does do it try taking the combustion door off does it now run normally?it may hunt[flame table]but is it know behaving?if so you have either a blocked venturi or failing ap switch if not look at diverter valve,motor or ntc
do a thorough check of the aps silicone pipes for holes/splits/loose connections as this can cause these symptoms, it took me a while to trace on a glow worm recently.
Reply to the thread, titled "ideal mini combi" which is posted in UK Plumbers Forums on Plumbers Forums.
